跳转到主内容
加入维修社区 - 创建账户
Body Cover Removal
你所需要的
  1. Body Cover Removal, Remove back cover: 步骤 1 中的图像 1,1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Body Cover Removal, Remove bottom cover: 步骤 2 中的图像 1,1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Body Cover Removal, Remove left front cover: 步骤 3 中的图像 1,1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Body Cover Removal, Remove front cover: 步骤 4 中的图像 1,2 Body Cover Removal, Remove front cover: 步骤 4 中的图像 2,2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Body Cover Removal, Remove right front cover: 步骤 5 中的图像 1,1
    • Remove two 3.9 mm #00 screws.
结论
Sam Gustafson
于09/01/22注册
10,464 声望
创作了57篇指南
2指南评论
Do you know is the leatherette is removable?
cavjer123 - 回复
It should be. I haven't done it but it is a separate piece from the plastic panels. Try applying some isopropyl alcohol along an edge to soften the adhesive, then work a dull scraper underneath. It should come off without too much effort.
Sam Gustafson -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 24
总计 561
