跳转到主内容
Blu Studio HD 6.0 Volume Buttons replacement
你所需要的
  1. Blu Studio HD 6.0 Volume Buttons replacement, Rear Case: 步骤 1 中的图像 1,1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Volume Buttons replacement, Back Panel.: 步骤 2 中的图像 1,2 Blu Studio HD 6.0 Volume Buttons replacement, Back Panel.: 步骤 2 中的图像 2,2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Volume Buttons replacement: 步骤 3 中的图像 1,2 Blu Studio HD 6.0 Volume Buttons replacement: 步骤 3 中的图像 2,2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Volume Buttons replacement, Midframe: 步骤 4 中的图像 1,2 Blu Studio HD 6.0 Volume Buttons replacement, Midframe: 步骤 4 中的图像 2,2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Volume Buttons replacement: 步骤 5 中的图像 1,1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Volume Buttons replacement: 步骤 6 中的图像 1,1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Volume Buttons replacement: 步骤 7 中的图像 1,1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Volume Buttons replacement, Locate the volume buttons.: 步骤 8 中的图像 1,1
    • The volume buttons are located on the rear-upper-right side of your Blu Studio phone.
  9. Blu Studio HD 6.0 Volume Buttons replacement, Replace the buttons.: 步骤 9 中的图像 1,2 Blu Studio HD 6.0 Volume Buttons replacement, Replace the buttons.: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers lift the volume buttons and unsolder the buttons connection.
  10. Blu Studio HD 6.0 Volume Buttons replacement, Solder the new buttons.: 步骤 10 中的图像 1,2 Blu Studio HD 6.0 Volume Buttons replacement, Solder the new buttons.: 步骤 10 中的图像 2,2
    • Finally you solder the new buttons to the motherboard of your Blu Studio.
    • Make sure that your buttons are placed as shown in the picture.
结论
另外一个人完成了本指南。
Ernesto Diaz
于09/23/14注册
1,759 声望
创作了3篇指南
团队
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G1
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,878
