跳转到主内容
Blu Studio HD 6.0 SIM Card Replacement
你所需要的
  1. Blu Studio HD 6.0 SIM Card Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: 步骤 2 中的图像 1,2 Blu Studio HD 6.0 SIM Card Replacement, Back Panel.: 步骤 2 中的图像 2,2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 SIM Card Replacement: 步骤 3 中的图像 1,2 Blu Studio HD 6.0 SIM Card Replacement: 步骤 3 中的图像 2,2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 SIM Card Replacement, Find out if your Blu Studio 6.0 is "unlocked.": 步骤 4 中的图像 1,1
    • Look at the sticker on top of the battery housing and note the model, part number and type.
    • Research this information to find out if you have an unlocked version of the phone.
    • If your phone is unlocked you can use any mobile network SIM card. If not you must replace the SIM card with a card from your carrier.
  5. Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 步骤 5 中的图像 1,3 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 步骤 5 中的图像 2,3 Blu Studio HD 6.0 SIM Card Replacement, Installing the SIM Card: 步骤 5 中的图像 3,3
    • If necessary slide the unneeded SIM card out of it's slot.
    • Make sure your new SIM card has been activated by the carrier.
    • Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
  6. Blu Studio HD 6.0 SIM Card Replacement, Turn the phone on: 步骤 6 中的图像 1,1
    • Turn on your Studio 6.0 and test it to make sure that everything is working.
    • If your phone gives you an error, check your SIM card installation. If everything seems to be correct make sure your SIM card is activated.
    • If everything is working you're good to go.
结论
7等其他人完成本指南。
Alec
于09/23/14注册
617 声望
创作了2篇指南
团队
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G1
3 名成员
创作了8篇指南
13条评论
Okay so my Sim has been working for months just 2 days ago my phone wouldn't turn on and then we'll now it doesn't read the Sim card idk what's going on with this but its getting annoying
caitlin - 回复
i know i am having the same issue. it is saying my sim card is off and to turn it on
jsllndr84 -
Its saying my Sim card is off..how do I turn it on.
victor ayitey - 回复
I just got this phone and I install the sim card like they say and it still says no sim card
Cheryl Dean - 回复
I have activated metro pcs sim. Unlocked blu studio g2 6.0 will not detect sim wtf?
Tim - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 40
总计 44,993
