简介
Before starting make sure you have your soldering workstation ready for use.
你所需要的
To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
After removing all 16 screws you can begin the process of removing the battery housing panel.
You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
Try to be careful around the side buttons as the plastic is weakest there.
After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
The power button is located on the rear-left side of your phone just above the battery.
Solder the new power button in the spot shown in the picture.
Fit the button on the side of the phone.
4等其他人完成本指南。
