跳转到主内容
Blu Studio HD 6.0 Microphone Replacement
你所需要的
  1. Blu Studio HD 6.0 Microphone Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Begin by making sure your Blu Studio is turned off.
  2. Blu Studio HD 6.0 Microphone Replacement, Back Panel.: 步骤 2 中的图像 1,2 Blu Studio HD 6.0 Microphone Replacement, Back Panel.: 步骤 2 中的图像 2,2
    • To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
  3. Blu Studio HD 6.0 Microphone Replacement: 步骤 3 中的图像 1,2 Blu Studio HD 6.0 Microphone Replacement: 步骤 3 中的图像 2,2
    • Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
    • Your rear panel should be placed nearby and in a safe location until you are finished with your task.
  4. Blu Studio HD 6.0 Microphone Replacement, Midframe: 步骤 4 中的图像 1,2 Blu Studio HD 6.0 Microphone Replacement, Midframe: 步骤 4 中的图像 2,2
    • With your back panel already removed from the previous guide you'll need to acquire a Philips head screw driver size (PH00)
  5. Blu Studio HD 6.0 Microphone Replacement: 步骤 5 中的图像 1,1
    • Next proceed to remove all 16 screws (2.5mm in length), all screws are the same size so getting them mixed up will not be an issue later on.
    • One of the lower right hand screws will be hidden under a sticker.
  6. Blu Studio HD 6.0 Microphone Replacement: 步骤 6 中的图像 1,1
    • After removing all 16 screws you can begin the process of removing the battery housing panel.
    • You will need to use the thinner plastic prying tool to slowly outline the seem of the case starting from the top (near the camera).
    • Try to be careful around the side buttons as the plastic is weakest there.
    • After the top half of the case has been opened insert the thicker prying tool to keep the case open. This will help as the battery and battery housing have a suction cup like action that keeps them from separating.
  7. Blu Studio HD 6.0 Microphone Replacement: 步骤 7 中的图像 1,1
    • At this point your battery, motherboard, rear camera, and front camera should all be readily available for fixing. Happy fixing.
  8. Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: 步骤 8 中的图像 1,2 Blu Studio HD 6.0 Microphone Replacement, Locate the microphone.: 步骤 8 中的图像 2,2
    • The microphone is located at the rear-lower-left corner.
  9. Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: 步骤 9 中的图像 1,2 Blu Studio HD 6.0 Microphone Replacement, Separate the old microphone.: 步骤 9 中的图像 2,2
    • Lift the microphone very carefully.
    • Unsolder the two lower wires ( one red wire and one black wire ).
  10. Blu Studio HD 6.0 Microphone Replacement, Solder the new microphone.: 步骤 10 中的图像 1,1
    • Solder the new microphone in the same spot. The black wire will go in the lower spot and the red wire in the upper spot.
结论
6等其他人完成本指南。
Ernesto Diaz
于09/23/14注册
1,759 声望
创作了3篇指南
团队
USF Tampa, Team 9-1, Blackwell Fall 2014 USF Tampa, Team 9-1, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S9G1
3 名成员
创作了8篇指南
2条评论
Where can I get a blue microphone for my BLU phone. When I answer my BLU phone I can't hear the person on the other line but they cannot hear me so I believe it's just my microphone when I speak.
Christina - 回复
Where can I buy microphones
b langdon - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 8
总计 13,592
