跳转到主内容
Blu Studio 5.5 Sub PCBA Replacement
你所需要的
  1. Blu Studio 5.5 Sub PCBA Replacement, Battery: 步骤 1 中的图像 1,3 Blu Studio 5.5 Sub PCBA Replacement, Battery: 步骤 1 中的图像 2,3 Blu Studio 5.5 Sub PCBA Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Sub PCBA Replacement: 步骤 2 中的图像 1,2 Blu Studio 5.5 Sub PCBA Replacement: 步骤 2 中的图像 2,2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Sub PCBA Replacement: 步骤 3 中的图像 1,3 Blu Studio 5.5 Sub PCBA Replacement: 步骤 3 中的图像 2,3 Blu Studio 5.5 Sub PCBA Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Sub PCBA Replacement, Back Panel Assembly: 步骤 4 中的图像 1,2 Blu Studio 5.5 Sub PCBA Replacement, Back Panel Assembly: 步骤 4 中的图像 2,2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Sub PCBA Replacement: 步骤 5 中的图像 1,3 Blu Studio 5.5 Sub PCBA Replacement: 步骤 5 中的图像 2,3 Blu Studio 5.5 Sub PCBA Replacement: 步骤 5 中的图像 3,3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Sub PCBA Replacement, Sub PCBA: 步骤 6 中的图像 1,2 Blu Studio 5.5 Sub PCBA Replacement, Sub PCBA: 步骤 6 中的图像 2,2
    • Locate the screw holding down the sub PCBA.
    • Remove the screw using the Phillips #000 screwdriver.
  7. Blu Studio 5.5 Sub PCBA Replacement: 步骤 7 中的图像 1,3 Blu Studio 5.5 Sub PCBA Replacement: 步骤 7 中的图像 2,3 Blu Studio 5.5 Sub PCBA Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the gold plated cable connecting the sub PCBA to the motherboard.
    • Locate the flex cable connector just above the sub PCBA screw.
    • Using tweezers, detach both cables from the sub PCBA.
  8. Blu Studio 5.5 Sub PCBA Replacement: 步骤 8 中的图像 1,2 Blu Studio 5.5 Sub PCBA Replacement: 步骤 8 中的图像 2,2
    • Note the red and blue wires connecting the sub PCBA to the speakers.
    • Either the speaker will need to be loosened and removed alongside the sub PCBA or the wires disconnected and resoldered during reassembly.
    • Using tweezers, grab the PCBA and remove gently from assembly.
结论
Alec Coleman
于02/28/17注册
313 声望
创作了3篇指南
团队
USF Tampa, Team S1-G6, Nance Spring 2017 USF Tampa, Team S1-G6, Nance Spring 2017 的会员
USFT-NANCE-S17S1G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 488
