跳转到主内容
Blu Studio 5.5 S Battery Replacement
  1. Blu Studio 5.5 S Battery Replacement, Back Casing: 步骤 1 中的图像 1,1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Battery Replacement, Applying Pressure: 步骤 2 中的图像 1,3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: 步骤 2 中的图像 2,3 Blu Studio 5.5 S Battery Replacement, Applying Pressure: 步骤 2 中的图像 3,3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
  3. Blu Studio 5.5 S Battery Replacement, Battery: 步骤 3 中的图像 1,3 Blu Studio 5.5 S Battery Replacement, Battery: 步骤 3 中的图像 2,3 Blu Studio 5.5 S Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Once the back case is removed, locate the battery. It is the large brick embedded in the phone. It has BLU Products, a caution statement, and a barcode on it.
    • Insert your finger into the notch near the lower left of the battery, apply pressure and lift up.
结论
7等其他人完成本指南。
Cody Dyl
于10/27/14注册
804 声望
创作了5篇指南
团队
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G8
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 6,132
