跳转到主内容
Blu Studio 5.5 S Back Case Replacement
  1. Blu Studio 5.5 S Back Case Replacement, Back Casing: 步骤 1 中的图像 1,1
    • In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
  2. Blu Studio 5.5 S Back Case Replacement, Applying Pressure: 步骤 2 中的图像 1,3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: 步骤 2 中的图像 2,3 Blu Studio 5.5 S Back Case Replacement, Applying Pressure: 步骤 2 中的图像 3,3
    • Place your finger in the small notch on the left side of the charging port (facing from the back).
    • Once your finger is in the notch, pull the back case towards yourself to remove it.
结论
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 4-8, Miles Fall 2014 UMass Dartmouth, Team 4-8, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G8
2 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 988
