跳转到主内容
加入维修社区 - 创建账户
Blu Studio 5.5 Micro USB Port Replacement
你所需要的
  1. Blu Studio 5.5 Micro USB Port Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over your Studio 5.5 so the back is facing you.
    • Use either the spudger or your fingernail to pull up on the slot in the lower left corner and remove the back cover.
  2. Blu Studio 5.5 Micro USB Port Replacement: 步骤 2 中的图像 1,2 Blu Studio 5.5 Micro USB Port Replacement: 步骤 2 中的图像 2,2
    • Place your finger in the small groove beneath the battery.
    • Push the battery toward the top of the phone and lift it out.
  3. Blu Studio 5.5 Micro USB Port Replacement, Micro USB Port: 步骤 3 中的图像 1,1
    • Begin by removing the 12 screws along the back of the device.
    • 1 of these screws will be underneath a white sticker. Just press the screwdriver through it and remove it normally.
    • 5 of these screws are 3.5mm, while the remaining 7 are 5mm.
  4. Blu Studio 5.5 Micro USB Port Replacement: 步骤 4 中的图像 1,2 Blu Studio 5.5 Micro USB Port Replacement: 步骤 4 中的图像 2,2
    • Using your plastic opening tool, begin carefully prying the plastic shell from the phone.
    • Make your way around the edge slowly and lift the shell off when you have made a full circuit.
  5. Blu Studio 5.5 Micro USB Port Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    • Using your tweezers, locate the small gold-colored plug in the bottom left corner and pull it straight out.
  6. Blu Studio 5.5 Micro USB Port Replacement: 步骤 6 中的图像 1,1
    • Use the tweezers again to pull out a small black plug in the bottom middle.
  7. Blu Studio 5.5 Micro USB Port Replacement: 步骤 7 中的图像 1,1
    • Grip the entire circuit board firmly with your tweezers and pull it towards the bottom of the phone and out.
  8. Blu Studio 5.5 Micro USB Port Replacement: 步骤 8 中的图像 1,1
    • Pry the speaker from the phone with your tweezers.
    • The speaker is glued to the rest of the phone and soldered to the circuit board.
结论
6等其他人完成本指南。
Brian Sullivan
于10/22/14注册
647 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-2, Shastany Fall 2014 UMass Dartmouth, Team 1-2, Shastany Fall 2014 的会员
UMASSD-SHASTANY-F14S1G2
3 名成员
创作了3篇指南
3指南评论
Should I change the other parts aswell?
branfay1 - 回复
i want buy chargin port sir my blue cahrging port was dead plz help me i want buy
muhammadfaisalkhan98 - 回复
Where do i buy the %#*@ micro usb port
PoPeYe MaStEr - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 4,414
