跳转到主内容
加入维修社区 - 创建账户
Blu Studio 5.5 Back Camera Replacement
你所需要的
  1. Blu Studio 5.5 Back Camera Replacement, Battery: 步骤 1 中的图像 1,3 Blu Studio 5.5 Back Camera Replacement, Battery: 步骤 1 中的图像 2,3 Blu Studio 5.5 Back Camera Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. Blu Studio 5.5 Back Camera Replacement: 步骤 2 中的图像 1,2 Blu Studio 5.5 Back Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. Blu Studio 5.5 Back Camera Replacement: 步骤 3 中的图像 1,3 Blu Studio 5.5 Back Camera Replacement: 步骤 3 中的图像 2,3 Blu Studio 5.5 Back Camera Replacement: 步骤 3 中的图像 3,3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. Blu Studio 5.5 Back Camera Replacement, Back Panel Assembly: 步骤 4 中的图像 1,2 Blu Studio 5.5 Back Camera Replacement, Back Panel Assembly: 步骤 4 中的图像 2,2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. Blu Studio 5.5 Back Camera Replacement: 步骤 5 中的图像 1,3 Blu Studio 5.5 Back Camera Replacement: 步骤 5 中的图像 2,3 Blu Studio 5.5 Back Camera Replacement: 步骤 5 中的图像 3,3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. Blu Studio 5.5 Back Camera Replacement, Motherboard: 步骤 6 中的图像 1,3 Blu Studio 5.5 Back Camera Replacement, Motherboard: 步骤 6 中的图像 2,3 Blu Studio 5.5 Back Camera Replacement, Motherboard: 步骤 6 中的图像 3,3
    • Locate the motherboard that is above where the battery was removed.
    • Remove the three screws holding down the motherboard to the phone.
    • Locate all 7 flex cable connectors that are attached to the motherboard.
  7. Blu Studio 5.5 Back Camera Replacement: 步骤 7 中的图像 1,3 Blu Studio 5.5 Back Camera Replacement: 步骤 7 中的图像 2,3 Blu Studio 5.5 Back Camera Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    • Use tweezers to carefully grasp and unhook all 7 flex cable connectors.
    • With the same tweezers, pry off the cable clasp that connects the motherboard to the sub PCBA.
    • Once the motherboard is disconnected from all components, use the tweezers or your fingers to remove it from the phone assembly.
    • Use the Anti-Static Wrist Strap to eliminate the possibility of introducing a static force that may damage the motherboard components.
  8. Blu Studio 5.5 Back Camera Replacement, Back Camera: 步骤 8 中的图像 1,3 Blu Studio 5.5 Back Camera Replacement, Back Camera: 步骤 8 中的图像 2,3 Blu Studio 5.5 Back Camera Replacement, Back Camera: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • After the motherboard has been removed you will see the back camera, which is glued to the phone assembly.
    • Using a pair of tweezers grip onto the sides of the camera and gently pry it off the panel.
    • Make sure that when you put in the replacement it is adhered to the phone panel and the flex cable connector goes in through the motherboard opening.
结论
团队
USF Tampa, Team S1-G6, Nance Spring 2017 USF Tampa, Team S1-G6, Nance Spring 2017 的会员
USFT-NANCE-S17S1G6
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 432
