本指南有最近更改,您可查看未经巡查的最新版本。
简介
If you are in need of replacing your BLU GRAND M2 display screen, this guide will help replacing it in a matter of time and easy as six steps on your own. This guide will show you how to remove the back panel, loosen screws, removing the motherboard , and removing the screen.
你所需要的
Before beginning the guide, be assure that this is the replacement guide you are about to begin. (figure 1)
After assuring the guide, begin by locating the torx screws beneath the phone, and remove them. (figure 2)
Using the suction tool, you can now begin by slowly pulling out the display screen show in (figure 1)
Use the pry tool to completely detach the display screen from the phone. (figure 2 )
Finally, the display is removed and attach your new screen.
After applying the new screen, use the steps in reverse order to reassemble the phone.
