跳转到主内容
Blu Grand M2 Power Button Replacement
你所需要的
  1. Blu Grand M2  Power Button Replacement, Power Button: 步骤 1 中的图像 1,1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: 步骤 2 中的图像 1,2 Blu Grand M2  Power Button Replacement: 步骤 2 中的图像 2,2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: 步骤 3 中的图像 1,1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: 步骤 4 中的图像 1,1
    • Place the new BLU Grand M2 power button in the socket.
结论
Alan Rodriguez
于09/10/18注册
311 声望
创作了2篇指南
团队
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018 的会员
GCC-LUSTER-F18S1G3
4 名成员
创作了4篇指南
一条评论
Don’t forget to remove the SIM card
Jonathan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 342
