简介
If the phone does not recognize sound while recording video or making phone calls you may need to replace the microphone. The microphone is glued in place. There my be yellow tape holding a wire in place that can be removed but cannot be replaced, it does not effect the functionality of the phone.
你所需要的
Remove the exterior cover with a Torx 2 screwdriver, to remove two 3.0mm screws.
Remove the 4.0mm screw with a Phillips #000 screwdriver.
Using the blue plastic opening tool, remove the exterior cover.
另外一个人完成了本指南。
