跳转到主内容
Blu Dash 5.0 Dual SIM Speaker Replacement
你所需要的
  1. Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Blu Dash 5.0 Dual SIM Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Make sure device is disconnected and turned off.
    • Locate the groove at the bottom left corner of the phone.
    • Insert the plastic opening tool in the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 2 中的图像 1,1
    • Pry the battery out from the back of the phone using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the 12 screws located at the back panel of the phone using a J000 screwdriver.
    • The red circles are screw holes that hold the 3.5mm length Phillips screw.
    • The orange circles are screw holes that hold the 2.5mm length Phillips screw.
  4. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 4 中的图像 1,3 Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 4 中的图像 2,3 Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 4 中的图像 3,3
    • Remove the back panel of the phone with your hand.
    • Carefully remove the plastic back panel to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the antenna cable connectors using a spudger.
  6. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 6 中的图像 1,1
    • Unscrew the 2.5mm screws from the circuit board holding the speaker at the bottom of the phone.
  7. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 7 中的图像 1,2 Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Flip the ZIF flap up with tweezers.
    • Remove the ribbon cable with tweezers.
    • The ribbon cable is sensitive and needs to be removed carefully to insure its integrity.
  8. Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 8 中的图像 1,2 Blu Dash 5.0 Dual SIM Speaker Replacement: 步骤 8 中的图像 2,2
    • Remove the speaker panel with the plastic opening tool.
    • The panel is glued onto the device and will require extra force to remove.
结论
Mukish Kumar Munyady
于01/30/17注册
201 声望
创作了2篇指南
团队
IUPUI, Team 1-1, Baechle Spring 2017 IUPUI, Team 1-1, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 282
