跳转到主内容
Blu Dash 5.0 Dual SIM Battery Replacement
你所需要的
  1. Blu Dash 5.0 Dual SIM Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the small slot on the bottom left corner of the back panel.
    • Slide the spudger into the small slot and lightly twist it. This will cause the corner of the back panel to pop up.
    • When the back panel is loose enough, use your fingers to remove it completely.
  2. Blu Dash 5.0 Dual SIM Battery Replacement: 步骤 2 中的图像 1,1
    • With the back panel off, you should see a large white rectangle. This is the battery. Slide the spudger under the indent on the bottom right of the battery and pull it up.
结论
5等其他人完成本指南。
Dashaya Toney
于10/27/14注册
876 声望
创作了3篇指南
团队
UMass Dartmouth, Team 4-7, Miles Fall 2014 UMass Dartmouth, Team 4-7, Miles Fall 2014 的会员
UMASSD-MILES-F14S4G7
3 名成员
创作了3篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 4,074
