跳转到主内容
Blu Dash 5.0 Dual SIM Back Camera Replacement
你所需要的
  1. Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: 步骤 1 中的图像 1,2 Blu Dash 5.0 Dual SIM Back Camera Replacement, Back Camera: 步骤 1 中的图像 2,2
    • Make sure device is disconnected and turned off.
    • Locate the groove on the bottom left corner of the back of the phone.
    • Insert the plastic opening tool into the groove and pry it open.
    • Lift the back cover of the phone using your hands.
  2. Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 2 中的图像 1,1
    • Pry the battery out using the plastic opening tool.
  3. Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 3 中的图像 1,1
    • Remove the 12 screws on the back panel using a J000 screwdriver.
    • Red circles correspond to the screw holes holding 3.5 mm length Phillips screws.
    • Orange circles correspond to the screw holes holding 2.5 mm length Phillips screws.
  4. Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 4 中的图像 1,3 Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 4 中的图像 2,3 Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 4 中的图像 3,3
    • Peel off the back panel with your hand.
    • Remove the back panel slowly to avoid breaking it.
  5. Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 5 中的图像 1,3 Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 5 中的图像 2,3 Blu Dash 5.0 Dual SIM Back Camera Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Flip up the ZIF flap using the spudger.
    • Gently remove the ribbon cable with tweezers.
    • The ribbon cable is sensitve and needs to be removed carefully to insure its integrity.
    • Remove the back camera using tweezers.
结论
Mukish Kumar Munyady
于01/30/17注册
201 声望
创作了2篇指南
团队
IUPUI, Team 1-1, Baechle Spring 2017 IUPUI, Team 1-1, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S1G1
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 387
