跳转到主内容
Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement
你所需要的
  1. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: 步骤 1 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: 步骤 1 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement, Fan: 步骤 1 中的图像 3,3
    • Make sure the diffuser is not plugged into a socket and that there is no water or oil near or in the diffuser before beginning the guide.
    • Use a Phillips #2 screwdriver to remove the four 8 mm screws on the bottom of the diffuser.
  2. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 2 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 2 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 2 中的图像 3,3
    • Lift the ceramic top of the oil diffuser.
    • Then lift off the plastic top off the diffuser.
  3. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 3 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 3 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 3 中的图像 3,3
    • Lift the last plastic lid.
    • You will see a circuit board, and there will be a cord connecting it to the circuit board.
  4. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 4 中的图像 1,2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 4 中的图像 2,2
    • Gently unplug the cord from the circuit board.
    • Place the plastic lid somewhere safe on the a flat surface.
  5. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 5 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 5 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 5 中的图像 3,3
    • Remove the plastic ring and place somewhere safe on a flat surface.
  6. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 6 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 6 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 6 中的图像 3,3
    • Remove two Truss head 4 mm screws with a Phillips #2 screwdriver and place safely nearby.
  7. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 7 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 7 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 7 中的图像 3,3
    • Gently lift the circuit board onto it's side
    • The white connector plugs the fan into the circuit board.
  8. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 8 中的图像 1,2 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 8 中的图像 2,2
    • Unplug the white connector.
    • There are four #M1 6 mm Phillips pan head screws holding down the fan.
  9. Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 9 中的图像 1,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 9 中的图像 2,3 Blossom Ultrasonic Essential Oil Diffuser ARM-510GY Fan Replacement: 步骤 9 中的图像 3,3
    • Remove the #M1 6 mm screws with a Phillips #2 screwdriver while holding down the fan.
    • Gently lift the fan and place the fan someplace safe on the flat surface.
结论
Muniira Mohamoud
于01/18/22注册
169 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 18
总计 359
