跳转到主内容
Blink Video Doorbell Back Panel Replacement
你所需要的
  1. Blink Video Doorbell Back Panel Replacement, Battery: 步骤 1 中的图像 1,3 Blink Video Doorbell Back Panel Replacement, Battery: 步骤 1 中的图像 2,3 Blink Video Doorbell Back Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Push the opening key into the small opening with the two gray buttons on the bottom of the device.
    • The device will click off the mount.
    • Push the device up from the mount and slide it off.
  2. Blink Video Doorbell Back Panel Replacement: 步骤 2 中的图像 1,3 Blink Video Doorbell Back Panel Replacement: 步骤 2 中的图像 2,3 Blink Video Doorbell Back Panel Replacement: 步骤 2 中的图像 3,3
    • Use your finger to slide the gray tab, located near the bottom of the device, upwards.
    • Remove the battery cover.
  3. Blink Video Doorbell Back Panel Replacement: 步骤 3 中的图像 1,3 Blink Video Doorbell Back Panel Replacement: 步骤 3 中的图像 2,3 Blink Video Doorbell Back Panel Replacement: 步骤 3 中的图像 3,3
    • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
    • Repeat the procedure for the left battery.
    • Do not mix used and new batteries or batteries of different types (for example, lithium and alkaline batteries).
  4. Blink Video Doorbell Back Panel Replacement, Back Panel: 步骤 4 中的图像 1,3 Blink Video Doorbell Back Panel Replacement, Back Panel: 步骤 4 中的图像 2,3 Blink Video Doorbell Back Panel Replacement, Back Panel: 步骤 4 中的图像 3,3
    • Remove the two 6 mm screws in the battery compartment using a JIS #1 screwdriver.
    • Remove the two 7 mm screws above the battery compartment using a JIS #1 screwdriver.
    • Starting from the bottom of the device, pry the back plate away from the rest of the doorbell.
结论
Kristen Gismondi
于11/12/14注册
99,439 声望
创作了255篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,629篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 35
总计 342
