跳转到主内容
Blackberry Z20 Leap LCD/Digitizer Replacement Replacement
你所需要的
  1. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, Blackberry Leap Screen Replacement: 步骤 1 中的图像 1,2 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, Blackberry Leap Screen Replacement: 步骤 1 中的图像 2,2
    • Blackberry Z20 Leap (STR200-2) with a bad LCD. The first question is...Where are the screws?
  2. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, remove screws: 步骤 2 中的图像 1,2 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, remove screws: 步骤 2 中的图像 2,2
    • The screws are behind the sticker beside the camera. Heat the sticker and use a knife to pry under the sticker to remove it. There are 2 screws which you need a T6 torx screwdriver to remove.
  3. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: 步骤 3 中的图像 1,3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: 步骤 3 中的图像 2,3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, unseat screen assembly: 步骤 3 中的图像 3,3
    • Push up on screen with thumbs once the screws have been removed. The screen assembly will now come away from the chassis. Be careful there is still some ribbon cables connected to the screen assembly.
  4. Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: 步骤 4 中的图像 1,3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: 步骤 4 中的图像 2,3 Blackberry Z20 Leap LCD/Digitizer Replacement Replacement, disconnect connectors: 步骤 4 中的图像 3,3
    • In the top there is a connector where you have to lift the black part of the connector to remove the ribbon. I used tweezers to lift the connector and to remove the ribbon cable
    • Once the top ribbon is removed there is another cable connected in the middle. The phone will open up more to give you access. You will need to lift the black part of the connector to remove the ribbon. Again, I used tweezers. The screen assembly should now come away from the chassis
结论
9等其他人完成本指南。
Amanda Baxter
于02/08/16注册
217 声望
撰写一个指南
8条评论
Excellent Guide Amanda! thanks for the great work!
Xpider - 回复
How to remove lcd from the frame (bezel)
Sani Shik - 回复
Can you advise how this is done please...removing the lcd from the frame
zoe smith -
I bought a T6 torx screwdriver but it is too big for my Leap (STR200-1). Any idea what size torx I need? I'm guessing T5 but...
Dave - 回复
Yep bought a T5 torx screwdriver and that did it
Dave - 回复
how do you remove the LCD screen from the frame
zoe smith - 回复
Thanks for the help!
bill wright - 回复
Where to buy a replacement screen ?
stephen.palermo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 5,344
