跳转到主内容
Blackberry Torch 9810 Screen Replacement
你所需要的
  1. Blackberry Torch 9810 Screen Replacement, Phone cover: 步骤 1 中的图像 1,2 Blackberry Torch 9810 Screen Replacement, Phone cover: 步骤 1 中的图像 2,2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Screen Replacement, Battery Removal: 步骤 2 中的图像 1,1
    • Remove the battery
  3. Blackberry Torch 9810 Screen Replacement, Remove Screws: 步骤 3 中的图像 1,1
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Screen Replacement, Wiggle Wiggle: 步骤 4 中的图像 1,2 Blackberry Torch 9810 Screen Replacement, Wiggle Wiggle: 步骤 4 中的图像 2,2
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Blackberry Torch 9810 Screen Replacement, More Screws: 步骤 5 中的图像 1,1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
    It opened using a T7 screw driver for my mobile at this step
    ershanu - 回复
  6. Blackberry Torch 9810 Screen Replacement, Remove the Back: 步骤 6 中的图像 1,3 Blackberry Torch 9810 Screen Replacement, Remove the Back: 步骤 6 中的图像 2,3 Blackberry Torch 9810 Screen Replacement, Remove the Back: 步骤 6 中的图像 3,3
    • Use the plastic removal tool to remove the entire back cover.
  7. Blackberry Torch 9810 Screen Replacement, Small Antenna Wire: 步骤 7 中的图像 1,1
    • Unplug the black antenna wire from the logic board.
  8. Blackberry Torch 9810 Screen Replacement, Remove Ribbon Cables: 步骤 8 中的图像 1,2 Blackberry Torch 9810 Screen Replacement, Remove Ribbon Cables: 步骤 8 中的图像 2,2
    • Peel off the three ribbon cables
    • They are orange and located on each side as well as on the top of the logic board
    • The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
  9. Blackberry Torch 9810 Screen Replacement, Logic Board: 步骤 9 中的图像 1,1
    • Take out your logic board
  10. Blackberry Torch 9810 Screen Replacement, Remove More Screws: 步骤 10 中的图像 1,1
    • Unscrew six small gold screws
  11. Blackberry Torch 9810 Screen Replacement, Remove the Screen: 步骤 11 中的图像 1,1
    • Separate the screen from its frame
    • After this step, you will need a torx bit smaller than a T-4. The circled display assembly can be replaced as a unit if you wish. In that case, this is the final step.
  12. Blackberry Torch 9810 Screen Replacement, Apply Heat to the Screen: 步骤 12 中的图像 1,1
    • Heat the digitizer
  13. Blackberry Torch 9810 Screen Replacement, Remove the Digizer: 步骤 13 中的图像 1,2 Blackberry Torch 9810 Screen Replacement, Remove the Digizer: 步骤 13 中的图像 2,2
    • Remove gold sticky film that attaches the digitizer to the screen
    • Separate the digitizer from its screen
    • Be careful not to tear the ribbon cable on the left side of the digitizer. That will be removed in a later step.
  14. Blackberry Torch 9810 Screen Replacement, Remove More Screws: 步骤 14 中的图像 1,1
    • Move the digitizer to remove both circled screws with a T-4 bit.
    • The screw in red is under the screen, be careful of the ribbon cable in the top left corner.
  15. Blackberry Torch 9810 Screen Replacement, Remove Even More Screws: 步骤 15 中的图像 1,1
    • Remove the circled screws with a T-2 bit.
    • Some kits do not have a bit small enough bit for these screws. If you do not have the proper bit, you should either buy one or simply replace the whole screen and digitizer assembly.
    • The silver plate may be covering up the screws. If you do not see them, slide it to the other end of the assembly.
  16. Blackberry Torch 9810 Screen Replacement, Separate the Screen Assembly: 步骤 16 中的图像 1,1
    • Use a plastic opening tool to separate the assembly.
  17. Blackberry Torch 9810 Screen Replacement, Remove the Digitizer: 步骤 17 中的图像 1,1
    • This ribbon cable comes out with a simple tug.
    • Pull the digitizer off the face of the phone and carefully guiding the ribbon cable out of the slot.
  18. Blackberry Torch 9810 Screen Replacement, Remove the Screen: 步骤 18 中的图像 1,2 Blackberry Torch 9810 Screen Replacement, Remove the Screen: 步骤 18 中的图像 2,2
    • Remove the screen using the opening tools.
    • The entire back of the screen is glued to the assembly, making it more difficult to remove. Since this part is already broken, don't be afraid to force it out.
结论
3等其他人完成本指南。
Jocelyn Adorno
于10/16/14注册
296 声望
创作了4篇指南
团队
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G6
3 名成员
创作了4篇指南
一条评论
Superb wish I could get the heating instrument can u just describe?
Freddy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 23
总计 5,095
