跳转到主内容
Blackberry Torch 9810 Rear Facing Camera Replacement
你所需要的
  1. Blackberry Torch 9810 Rear Facing Camera Replacement, Remove Cover: 步骤 1 中的图像 1,2 Blackberry Torch 9810 Rear Facing Camera Replacement, Remove Cover: 步骤 1 中的图像 2,2
    • Remove the back cover of the phone
  2. Blackberry Torch 9810 Rear Facing Camera Replacement, Remove Battery: 步骤 2 中的图像 1,1
    • Remove the battery
    • Our phone did not come with a battery. This is where it would be located.
  3. Blackberry Torch 9810 Rear Facing Camera Replacement, Unscrew Screws: 步骤 3 中的图像 1,2 Blackberry Torch 9810 Rear Facing Camera Replacement, Unscrew Screws: 步骤 3 中的图像 2,2
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Blackberry Torch 9810 Rear Facing Camera Replacement, Wiggle Wiggle: 步骤 4 中的图像 1,2 Blackberry Torch 9810 Rear Facing Camera Replacement, Wiggle Wiggle: 步骤 4 中的图像 2,2
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • (This is a little difficult to remove) Pull the bottom upward and pull the top downward.
  5. Blackberry Torch 9810 Rear Facing Camera Replacement, Smaller Screws That Must Go: 步骤 5 中的图像 1,1
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
  6. Blackberry Torch 9810 Rear Facing Camera Replacement, Camera Sensor: 步骤 6 中的图像 1,2 Blackberry Torch 9810 Rear Facing Camera Replacement, Camera Sensor: 步骤 6 中的图像 2,2
    • Use the Phillip screw driver to wiggle the camera sensor out.
    • Carefully remove this
结论
另外一个人完成了本指南。
Jocelyn Adorno
于10/16/14注册
296 声望
创作了4篇指南
团队
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,122
