跳转到主内容
  1. Remove the back cover of the phone Remove the back cover of the phone
    • Remove the back cover of the phone
  2. Remove the battery
    • Remove the battery
  3. Unscrew the four screws using the T6 screw driver
    • Unscrew the four screws using the T6 screw driver
    • If you remove the screw in red, you void the warranty!
  4. Remove front silver trim by using plastic opening tools and wiggle it off. This is difficult to remove, but it should come off if you do it with caution.
    • Remove front silver trim by using plastic opening tools and wiggle it off.
    • This is difficult to remove, but it should come off if you do it with caution.
  5. Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
    • Once you remove the rim cover, you should find two more screws on the top. Unscrew them using the T6 screw driver.
  6. Use the plastic removal tool to remove the entire back cover. Use the plastic removal tool to remove the entire back cover. Use the plastic removal tool to remove the entire back cover.
    • Use the plastic removal tool to remove the entire back cover.
  7. Unplug the black antenna wire from the logic board.
    • Unplug the black antenna wire from the logic board.
  8. Peel off the three ribbon cables They are orange and located on each side as well as on the top of the logic board
    • Peel off the three ribbon cables
    • They are orange and located on each side as well as on the top of the logic board
    • The cable circled in yellow is glued to the silver cap. Pull the ribbon cable upward towards the battery area.
  9. Take out your logic board
    • Take out your logic board
结论
5等其他人完成本指南。
Jocelyn Adorno
于2014年10月16日注册
296 信誉积分
创作了4篇指南
团队
UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-6, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S6G6
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 3,128
