跳转到主内容
Blackberry Torch 9800 Logic Board Replacement
你所需要的
  1. Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: 步骤 1 中的图像 1,2 Blackberry Torch 9800 Logic Board Replacement, Logic Board Replacement: 步骤 1 中的图像 2,2
    • Remove the back cover and the battery.
    • Unscrew the four screws using a T6 screwdriver.
    • Removing the top right screw (with the blue cover) will void the warranty.
  2. Blackberry Torch 9800 Logic Board Replacement: 步骤 2 中的图像 1,2 Blackberry Torch 9800 Logic Board Replacement: 步骤 2 中的图像 2,2
    • Remove the side trim using the plastic opening tool.
    • Apply pressure to push the top side of the side trim towards the phone while pulling the bottom away from the phone to remove the side trim.
    • The side trim is fragile and easily fractured, so handful it with care.
  3. Blackberry Torch 9800 Logic Board Replacement: 步骤 3 中的图像 1,3 Blackberry Torch 9800 Logic Board Replacement: 步骤 3 中的图像 2,3 Blackberry Torch 9800 Logic Board Replacement: 步骤 3 中的图像 3,3
    • Remove the two screws that have been revealed at the top of the device using the T6 screwdriver.
    • You should now be able to easily lift the back panel from the phone.
  4. Blackberry Torch 9800 Logic Board Replacement: 步骤 4 中的图像 1,2 Blackberry Torch 9800 Logic Board Replacement: 步骤 4 中的图像 2,2
    • Using your hands, carefully peel the three ribbon cable caps from the logic board.
  5. Blackberry Torch 9800 Logic Board Replacement: 步骤 5 中的图像 1,2 Blackberry Torch 9800 Logic Board Replacement: 步骤 5 中的图像 2,2
    • Lift logic board slightly. The logic board will remain attached to the phone by a small antenna wire.
    • Using your hands, carefully lift the clasp attached to the antenna wire straight upward away from the logic board.
    • Make sure not to disconnect the antenna wire from its clasp.
    • The logic board should now be completely separate from the phone.
结论
3等其他人完成本指南。
Keegan Williams
于02/19/16注册
216 声望
创作了2篇指南
团队
Ohio State, Team 1-5, Garvin Spring 2016 Ohio State, Team 1-5, Garvin Spring 2016 的会员
OSU-GARVIN-S16S1G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 11
总计 842
