跳转到主内容
Blackberry Storm 9530 Battery Replacement
你所需要的
  1. Blackberry Storm 9530 Battery Replacement, Back Cover Removal: 步骤 1 中的图像 1,3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: 步骤 1 中的图像 2,3 Blackberry Storm 9530 Battery Replacement, Back Cover Removal: 步骤 1 中的图像 3,3
    • Locate the two switches toward the bottom corners of the device's back cover.
    • Use your thumbs or fingers to push the two switches forward at the same time and detach the back cover from the device.
    • Check to make sure the back cover has fully detached from the device. You should be left with two separate pieces: the back cover, and the device with exposed internal hardware.
  2. Blackberry Storm 9530 Battery Replacement: 步骤 2 中的图像 1,1
    • Identify that the battery is visible once the back cover has been removed, and locate the battery in the rectangular-shaped top half of the device.
    • Pry apart the battery and back of the device using the flat end of your spudger tool or using your finger if you do not have a spudger.
    • Your battery has a specific orientation resembling a horizontal rectangle. Make sure the gold colored leads are aligned with the gold colored strips on your battery before reassembling.
结论
melanie lim
于04/22/14注册
607 声望
创作了6篇指南
团队
Cal Poly, Team 9-16, Regan Spring 2014 Cal Poly, Team 9-16, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G16
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,632
