跳转到主内容
Blackberry RIM 7250 Keyboard Replacement
你所需要的
  1. Blackberry RIM 7250 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Blackberry RIM 7250 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Blackberry RIM 7250 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Push the release button down and away from the device.
    • Slide the cover off toward the bottom of the device, revealing the battery compartment.
  2. Blackberry RIM 7250 Keyboard Replacement: 步骤 2 中的图像 1,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 2 中的图像 2,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Place your finger in the groove next to the battery.
    • Lift your finger up to eject the battery from the battery compartment.
  3. Blackberry RIM 7250 Keyboard Replacement: 步骤 3 中的图像 1,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 3 中的图像 2,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Remove the battery from the compartment.
  4. Blackberry RIM 7250 Keyboard Replacement, Back Housing: 步骤 4 中的图像 1,2 Blackberry RIM 7250 Keyboard Replacement, Back Housing: 步骤 4 中的图像 2,2
    • Remove the four 10.7 mm Torx T6 screws.
  5. Blackberry RIM 7250 Keyboard Replacement: 步骤 5 中的图像 1,2 Blackberry RIM 7250 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the two 5 mm Torx T6 screws.
  6. Blackberry RIM 7250 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Hold the phone with one hand, with the bottom facing toward you.
    • For both clips, insert the plastic opening tool and push away from you.
    • You will hear a clicking sound for each clip that is released.
  7. Blackberry RIM 7250 Keyboard Replacement: 步骤 7 中的图像 1,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 7 中的图像 2,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 7 中的图像 3,3
    • Grab the back housing from the bottom and lift the housing away from you.
  8. Blackberry RIM 7250 Keyboard Replacement, Front Housing: 步骤 8 中的图像 1,2 Blackberry RIM 7250 Keyboard Replacement, Front Housing: 步骤 8 中的图像 2,2
    • Place your thumb on the bottom rectangle and your index finger on the top rectangle.
    • Squeeze your fingers together to release the internals from the front housing.
  9. Blackberry RIM 7250 Keyboard Replacement: 步骤 9 中的图像 1,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 9 中的图像 2,3 Blackberry RIM 7250 Keyboard Replacement: 步骤 9 中的图像 3,3
    • Pull the two pieces apart to separate the front housing from the internals.
  10. Blackberry RIM 7250 Keyboard Replacement, Keyboard: 步骤 10 中的图像 1,3 Blackberry RIM 7250 Keyboard Replacement, Keyboard: 步骤 10 中的图像 2,3 Blackberry RIM 7250 Keyboard Replacement, Keyboard: 步骤 10 中的图像 3,3
    • Push the keyboard from the front view to separate it from the front housing.
  11. Blackberry RIM 7250 Keyboard Replacement: 步骤 11 中的图像 1,2 Blackberry RIM 7250 Keyboard Replacement: 步骤 11 中的图像 2,2
    • Hold the front housing with one hand and grab the keyboard with the other.
    • Pull each piece away from each other to remove the keyboard.
结论
Noah Eckert
于11/05/18注册
519 声望
创作了5篇指南
团队
IUPUI, Team S2-G4, Baechle Fall 2018 IUPUI, Team S2-G4, Baechle Fall 2018 的会员
IUPUI-BAECHLE-F18S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 428
