跳转到主内容
Blackberry Curve 9300 Speaker Replacement
你所需要的
  1. Blackberry Curve 9300 Speaker Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your Blackberry face down in front of you.
  2. Blackberry Curve 9300 Speaker Replacement: 步骤 2 中的图像 1,1
    • Locate the indent on the bottom of the back cover.
    • Use your fingernail to lift and remove the back cover.
  3. Blackberry Curve 9300 Speaker Replacement: 步骤 3 中的图像 1,1
    • From the top, use your fingernail to lift and remove the battery.
  4. Blackberry Curve 9300 Speaker Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Use the T6 Torx screwdriver to unscrew the two 5mm screws highlighted.
  5. Blackberry Curve 9300 Speaker Replacement: 步骤 5 中的图像 1,2 Blackberry Curve 9300 Speaker Replacement: 步骤 5 中的图像 2,2
    • Place the phone face up and use tweezers to securely grip and lift the screen upwards.
  6. Blackberry Curve 9300 Speaker Replacement: 步骤 6 中的图像 1,1
    • Use a plastic opening tool to lift the bottom edge of the front cover.
  7. Blackberry Curve 9300 Speaker Replacement: 步骤 7 中的图像 1,1
    • Use your nails to unclip the sides of the frame from the phone.
  8. Blackberry Curve 9300 Speaker Replacement: 步骤 8 中的图像 1,1
    • Lift and remove the frame.
  9. Blackberry Curve 9300 Speaker Replacement: 步骤 9 中的图像 1,1
    • Lift and remove the keyboard.
  10. Blackberry Curve 9300 Speaker Replacement, Speaker: 步骤 10 中的图像 1,1
    • Locate and remove the two 5mm screws on top of the keyboard base with a T6 Torx screwdriver.
  11. Blackberry Curve 9300 Speaker Replacement: 步骤 11 中的图像 1,1
    • Carefully pull keyboard base up and away from phone.
    • Disconnect keyboard base from phone completely.
  12. Blackberry Curve 9300 Speaker Replacement: 步骤 12 中的图像 1,3 Blackberry Curve 9300 Speaker Replacement: 步骤 12 中的图像 2,3 Blackberry Curve 9300 Speaker Replacement: 步骤 12 中的图像 3,3
    • Remove the four 5mm screws on the top and bottom of phone with a T6 Torx screwdriver
  13. Blackberry Curve 9300 Speaker Replacement: 步骤 13 中的图像 1,2 Blackberry Curve 9300 Speaker Replacement: 步骤 13 中的图像 2,2
    • Using a prying tool, find the crease below the screen.
    • Insert where shown and use the tool to unclip the two sides of screen from body.
    • Prying tool goes approximately midway between the top and bottom edge of the screen.
  14. Blackberry Curve 9300 Speaker Replacement: 步骤 14 中的图像 1,2 Blackberry Curve 9300 Speaker Replacement: 步骤 14 中的图像 2,2
    • From the back of the phone, use your finger to push the front piece of the phone away from the back piece.
  15. Blackberry Curve 9300 Speaker Replacement: 步骤 15 中的图像 1,1
    • Insert tweezers into the small holes on the top of the speaker.
  16. Blackberry Curve 9300 Speaker Replacement: 步骤 16 中的图像 1,2 Blackberry Curve 9300 Speaker Replacement: 步骤 16 中的图像 2,2
    • Lift the speaker up to remove the speaker from phone.
结论
6等其他人完成本指南。
Alek Squires
于09/30/13注册
431 声望
创作了2篇指南
团队
Cal Poly, Team 14-7, Forte Fall 2013 Cal Poly, Team 14-7, Forte Fall 2013 的会员
CPSU-FORTE-F13S14G7
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 4,134
