当前版本的文档还未经巡查,您可以查看最新的已查核版本。
We did not have an actual back cover or battery for the phone we were given. Therefore, the first couple of steps will be without pictures.
Hold the phone with the back side facing you.
Press down on the silver tab towards the bottom end of the phone.
Carefully lift up the back casing to reveal the battery.
Use a plastic opening tool to pry between the front and back cover.
Start prying from wherever it is easiest to separate the silver and black plastic of the covers.
There are 5 securing clips on the front panel to disconnect.
Pry gently to prevent breaking the plastic clips when removing the front panel.
Once all the clips have been freed, the front cover will lift away from the phone.
Use a T6 Torx Screwdriver to remove the four corner screws on the keyboard's housing.
Lift the keyboard frame away from the device.
There may be a small amount of adhesive at the bottom of the frame that needs to be pulled away.
Using a plastic opening tool, detach the connector on the LCD screen from the motherboard.
There may be some adhesive behind the LCD screen. If needed, pry the LCD screen away from the motherboard using the plastic opening tool.
Remove the LCD screen from the motherboard
Once the LCD screen is taken off, the motherboard is fully separated from the device.
The picture shown is the back side of the motherboard.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
