当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use a plastic opening tool to gently pry the bottom cover loose.
Do not use excessive force at risk of damaging the antenna, which is under this casing.
Pull the cover from the front of the phone after the back is loose.
Gently pry off the side casings from the top.
The side casings cannot be fully removed yet because they are screwed on at the bottom.
You will not need to remove the sides on the bottom.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
