跳转到主内容
Blackberry Curve 8320 Keyboard Replacement
你所需要的
  1. Blackberry Curve 8320 Keyboard Replacement, Front Panel: 步骤 1 中的图像 1,3 Blackberry Curve 8320 Keyboard Replacement, Front Panel: 步骤 1 中的图像 2,3 Blackberry Curve 8320 Keyboard Replacement, Front Panel: 步骤 1 中的图像 3,3
    • Use a plastic opening tool to gently pry the bottom cover loose.
    • Do not use excessive force at risk of damaging the antenna, which is under this casing.
    • Pull the cover from the front of the phone after the back is loose.
  2. Blackberry Curve 8320 Keyboard Replacement: 步骤 2 中的图像 1,2 Blackberry Curve 8320 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two top screws with a T5 Torx screwdriver.
    • The screws are 8mm long.
  3. Blackberry Curve 8320 Keyboard Replacement: 步骤 3 中的图像 1,2 Blackberry Curve 8320 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Gently pry off the side casings from the top.
    • The side casings cannot be fully removed yet because they are screwed on at the bottom.
    • You will not need to remove the sides on the bottom.
  4. Blackberry Curve 8320 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use a plastic opening tool to detach the securing clips holding the the front panel in place.
    • There are six securing clips total.
  5. Blackberry Curve 8320 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the front panel.
    • You may need to apply some force in removing because the front panel is attached to the rest of the device with adhesive.
  6. Blackberry Curve 8320 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,2 Blackberry Curve 8320 Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,2
    • Remove the keyboard.
    • Be careful not to bend or fold the keyboard, as it can break easily.
结论
另外一个人完成了本指南。
Yegor Pomortsev
于10/12/11注册
123 声望
创作了2篇指南
团队
Cal Poly, Team 3-6, Regan Fall 2011 Cal Poly, Team 3-6, Regan Fall 2011 的会员
CPSU-REGAN-F11S3G6
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,027
