本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will show you how to:
- Remove the battery
- Remove the front cover
- Replace the front panel
你所需要的
Hold the phone with the back facing you.
Press the silver tab down and remove the cover.
Use a plastic opening tool to gently pry the bottom cover loose.
Pull the cover from the front of the phone after the back is loose.
即将完成!
结论
另外一个人完成了本指南。
