跳转到主内容
Blackberry Curve 8310 Motherboard Replacement
你所需要的
  1. Blackberry Curve 8310 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. Blackberry Curve 8310 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Pry from the top of the battery to pull it out.
  3. Blackberry Curve 8310 Motherboard Replacement, Lens: 步骤 3 中的图像 1,1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. Blackberry Curve 8310 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. Blackberry Curve 8310 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. Blackberry Curve 8310 Motherboard Replacement: 步骤 6 中的图像 1,3 Blackberry Curve 8310 Motherboard Replacement: 步骤 6 中的图像 2,3 Blackberry Curve 8310 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. Blackberry Curve 8310 Motherboard Replacement, Keyboard: 步骤 7 中的图像 1,1
    • Remove the keyboard.
  8. Blackberry Curve 8310 Motherboard Replacement, Screen Housing: 步骤 8 中的图像 1,1
    • Remove the four T6 Torx screws located on the corners of the keyboard frame.
  9. Blackberry Curve 8310 Motherboard Replacement: 步骤 9 中的图像 1,2 Blackberry Curve 8310 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Now remove the left and right side panels.
  10. Blackberry Curve 8310 Motherboard Replacement: 步骤 10 中的图像 1,3 Blackberry Curve 8310 Motherboard Replacement: 步骤 10 中的图像 2,3 Blackberry Curve 8310 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove the keyboard frame.
    • Be sure to unhook the screen housing from the motherboard before continuing. Refer to the square indicated in the second picture.
    • Now remove the screen housing.
  11. Blackberry Curve 8310 Motherboard Replacement, LCD Screen: 步骤 11 中的图像 1,1
    • Unplug the ribbon cable from the board.
    • The ribbon cable is located at the top left of the phone above the screen.
  12. Blackberry Curve 8310 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Insert tool between LCD screen and board.
    • Pry LCD screen from board.
  13. Blackberry Curve 8310 Motherboard Replacement, Motherboard: 步骤 13 中的图像 1,1
    • Separate the motherboard from the back case.
结论
7等其他人完成本指南。
Sean Willis
于01/26/12注册
229 声望
创作了5篇指南
团队
Cal Poly, Team 10-32, Amido Winter 2012 Cal Poly, Team 10-32, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G32
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,349
