跳转到主内容
简介
Replacement of lcd and digitizer on a Q20
  1. Start by removing the back cover.
    • Start by removing the back cover.
    • It's glued on the top and at the bottom. Use an isesamo and gentle force to remove it
  2. Like many other blackberry models, lift out the small plastic edge at the bottom of the keyboard
    • Like many other blackberry models, lift out the small plastic edge at the bottom of the keyboard
    • This will reveal two torx screws to remove
  3. Turn the blackberry around and remove all torx screws
    • Turn the blackberry around and remove all torx screws
    • Separate the battery screws as they are different
    • Watch out for the 00 Philips screw on the top left corner
    • Remove the plastic mid-frame
  4. The battery is held firmly by glue (or space putty?)
    • The battery is held firmly by glue (or space putty?)
    • That 4$ card proved its utility
    • Be careful when removing the adhesive not to pry the small connectors at the base of the board.
  5. The board is clipped and lightly glued. Use tweezers to lift the retention clips under the board to release it.
    • The board is clipped and lightly glued. Use tweezers to lift the retention clips under the board to release it.
  6. Remove the micro usb connector, the audio jack and the 3 ph000 screws on the board.
    • Remove the micro usb connector, the audio jack and the 3 ph000 screws on the board.
    • This will allow you to push out the metal mid-frame
  7. Once screws are all out, gently lift the broken digitizer. Make sure to lift between the display assembly and the black border.
    • Once screws are all out, gently lift the broken digitizer. Make sure to lift between the display assembly and the black border.
    • Remove any remaining shattered glass from the display frame before reassembling.
    • Reassemble in reverse order
结论
19等其他人完成本指南。
coutureg
于2012年07月19日注册
777 信誉积分
撰写一个指南
团队
Techno-sos Techno-sos 的会员
Business
1 名成员
创作了1篇指南
If I’m just switching boards, is it even necessary to remove the battery? Can’t I just switch the boards with the batteries still attached to their respective boards? I just don’t see the point of removing the battery unless you are replacing it.
gary - 回复
If you are replacing the board and the battery, and can reach the retention clips under the board to lift the board out of the case, I guess it could be possible to replace both parts without separating them.
coutureg -
So I can confirm that you do not need to remove the battery to switch the boards. You can leave it stuck to the board.
https://imgur.com/a/FtY09en
gary - 回复
Interesting, thanks for the update ! Cheers !
coutureg -
You are welcome! Thanks for the great writeup coutureg
gary - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 15
过去的30天: 56
总计 13,844
