简介
Replacement of lcd and digitizer on a Q20
你所需要的
Start by removing the back cover.
It's glued on the top and at the bottom. Use an isesamo and gentle force to remove it
23等其他人完成本指南。
8条评论
If I’m just switching boards, is it even necessary to remove the battery? Can’t I just switch the boards with the batteries still attached to their respective boards? I just don’t see the point of removing the battery unless you are replacing it.
If you are replacing the board and the battery, and can reach the retention clips under the board to lift the board out of the case, I guess it could be possible to replace both parts without separating them.
coutureg -
So I can confirm that you do not need to remove the battery to switch the boards. You can leave it stuck to the board.
Interesting, thanks for the update ! Cheers !
coutureg -
