跳转到主内容
Blackberry Bold 9900 Trackpad Replacement
你所需要的
  1. Blackberry Bold 9900 Trackpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Trackpad Replacement: 步骤 2 中的图像 1,1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Trackpad Replacement, MicroSD card: 步骤 3 中的图像 1,2 Blackberry Bold 9900 Trackpad Replacement, MicroSD card: 步骤 3 中的图像 2,2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Trackpad Replacement, Keyboard: 步骤 4 中的图像 1,2 Blackberry Bold 9900 Trackpad Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Trackpad Replacement: 步骤 5 中的图像 1,2 Blackberry Bold 9900 Trackpad Replacement: 步骤 5 中的图像 2,2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Trackpad Replacement: 步骤 6 中的图像 1,1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Trackpad Replacement: 步骤 7 中的图像 1,2 Blackberry Bold 9900 Trackpad Replacement: 步骤 7 中的图像 2,2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  8. Blackberry Bold 9900 Trackpad Replacement, Trackpad: 步骤 8 中的图像 1,3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: 步骤 8 中的图像 2,3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: 步骤 8 中的图像 3,3
    • Push into the trackpad. This will release the trackpad supporting piece.
  9. Blackberry Bold 9900 Trackpad Replacement: 步骤 9 中的图像 1,2 Blackberry Bold 9900 Trackpad Replacement: 步骤 9 中的图像 2,2
    • The trackpad is attached via ribbon cable. Pull this cable up in order to release the trackpad.
结论
Chris Velasquez
于01/30/18注册
214 声望
创作了2篇指南
团队
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 972
