跳转到主内容
Blackberry Bold 9900 Memory Card Replacement
  1. Blackberry Bold 9900 Memory Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Memory Card Replacement: 步骤 2 中的图像 1,1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Memory Card Replacement, MicroSD card: 步骤 3 中的图像 1,2 Blackberry Bold 9900 Memory Card Replacement, MicroSD card: 步骤 3 中的图像 2,2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Memory Card Replacement, Mini-SIM removal: 步骤 4 中的图像 1,1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
结论
另外一个人完成了本指南。
Sowmika
于01/30/18注册
253 声望
创作了2篇指南
团队
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 871
