跳转到主内容
Blackberry Bold 9900 Back Case Replacement
你所需要的
  1. Blackberry Bold 9900 Back Case Replacement, Battery: 步骤 1 中的图像 1,1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Back Case Replacement: 步骤 2 中的图像 1,1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Back Case Replacement, Mini-SIM removal: 步骤 3 中的图像 1,1
    • The Mini-SIM card is located inside the red rectangle.
    • To remove the Mini-SIM Card, push and slide the card inward towards the top of the phone. It will be ejected.
  4. Blackberry Bold 9900 Back Case Replacement, MicroSD card: 步骤 4 中的图像 1,2 Blackberry Bold 9900 Back Case Replacement, MicroSD card: 步骤 4 中的图像 2,2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  5. Blackberry Bold 9900 Back Case Replacement, Keyboard: 步骤 5 中的图像 1,2 Blackberry Bold 9900 Back Case Replacement, Keyboard: 步骤 5 中的图像 2,2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  6. Blackberry Bold 9900 Back Case Replacement: 步骤 6 中的图像 1,2 Blackberry Bold 9900 Back Case Replacement: 步骤 6 中的图像 2,2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  7. Blackberry Bold 9900 Back Case Replacement: 步骤 7 中的图像 1,1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  8. Blackberry Bold 9900 Back Case Replacement: 步骤 8 中的图像 1,2 Blackberry Bold 9900 Back Case Replacement: 步骤 8 中的图像 2,2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  9. Blackberry Bold 9900 Back Case Replacement, Back Case: 步骤 9 中的图像 1,1
    • Using the T5 Torx Screwdriver, remove the four torx screws that are located on the bottom half of the device
  10. Blackberry Bold 9900 Back Case Replacement: 步骤 10 中的图像 1,1
    • Now, carefully and gently using your fingers, lift and remove the assembly from the back case.
结论
3等其他人完成本指南。
Sowmika
于01/30/18注册
253 声望
创作了2篇指南
团队
Baylor, Team S1-G4, Johnson Spring 2018 Baylor, Team S1-G4, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 17
总计 1,437
