本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Orient the device so that the screen is facing the ground, and the top of the phone is facing you.
Using a pair of tweezers, lift and remove the following:
The two round connectors on the top of the mother board.
The flat connector in the lower corner of the mother board.
另外一个人完成了本指南。
