当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the device upside down.
Using your finger, slide the silver cover release button towards the top of the device.
Lift and remove the back cover.
Using your fingernails, lift the sides of the battery.
Remove the battery.
Orient the device so that the screen is facing the ground.
Using your finger, gently lift the top of the SIM card.
Gently pull out the SIM card.
The card will break in half if you apply too much force when pulling out the card.
Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
Orient the device so that the screen is facing you.
Using a spudger, remove the ear piece cover.
Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
Remove the back chassis by gently pulling the chassis back and forth.
The headphone jack can break if the chassis is pulled too forcefully.
Use a plastic pry tool to remove the speaker.
Be careful removing removing the speaker as the plastic frame around the speaker is fragile.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于03/12/12注册
696 声望
创作了11篇指南
徽章: 12
+ 9更多徽章
CLEM-BENSON-S12S2G5
2 名成员
创作了14篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,961
