跳转到主内容
Blackberry Bold 9650 Back Chassis Replacement
你所需要的
  1. Blackberry Bold 9650 Back Chassis Replacement, Battery: 步骤 1 中的图像 1,2 Blackberry Bold 9650 Back Chassis Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the device upside down.
    • Using your finger, slide the silver cover release button towards the top of the device.
    • Lift and remove the back cover.
  2. Blackberry Bold 9650 Back Chassis Replacement: 步骤 2 中的图像 1,1
    • Using your fingernails, lift the sides of the battery.
    • Remove the battery.
  3. Blackberry Bold 9650 Back Chassis Replacement, SIM Card: 步骤 3 中的图像 1,1
    • Orient the device so that the screen is facing the ground.
    • Using your finger, gently lift the top of the SIM card.
  4. Blackberry Bold 9650 Back Chassis Replacement: 步骤 4 中的图像 1,1
    • Gently pull out the SIM card.
    • The card will break in half if you apply too much force when pulling out the card.
  5. Blackberry Bold 9650 Back Chassis Replacement, Back Chassis: 步骤 5 中的图像 1,1
    • Using a T6 Torx screwdriver, remove the four screws from the bottom half of the device.
  6. Blackberry Bold 9650 Back Chassis Replacement: 步骤 6 中的图像 1,1
    • Orient the device so that the screen is facing you.
    • Using a spudger, remove the ear piece cover.
  7. Blackberry Bold 9650 Back Chassis Replacement: 步骤 7 中的图像 1,1
    • Using a T6 Torx screwdriver, remove the two screws from the top corners of the device.
  8. Blackberry Bold 9650 Back Chassis Replacement: 步骤 8 中的图像 1,1
    • Remove the back chassis by gently pulling the chassis back and forth.
    • The headphone jack can break if the chassis is pulled too forcefully.
结论
5等其他人完成本指南。
Ryan
于03/12/12注册
696 声望
创作了11篇指南
团队
Clemson, Team 2-5, Benson Spring 2012 Clemson, Team 2-5, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G5
2 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 3,182
