跳转到主内容
Blackberry Bold 9000 Volume Toggle Replacement
你所需要的
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: 步骤 2 中的图像 1,1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: 步骤 3 中的图像 1,1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: 步骤 5 中的图像 1,1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: 步骤 7 中的图像 1,1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: 步骤 8 中的图像 1,1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: 步骤 9 中的图像 1,1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
结论
2等其他人完成本指南。
Kelly
于01/18/12注册
566 声望
创作了6篇指南
团队
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G17
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 2,471
