跳转到主内容
Blackberry Bold 9000 Trackball Replacement
你所需要的
  1. Blackberry Bold 9000 Trackball Replacement, Battery: 步骤 1 中的图像 1,1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: 步骤 2 中的图像 1,1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: 步骤 3 中的图像 1,1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: 步骤 4 中的图像 1,1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: 步骤 5 中的图像 1,1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: 步骤 7 中的图像 1,1
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: 步骤 8 中的图像 1,1
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: 步骤 9 中的图像 1,1
    • Lift the trackball out of its socket.
结论
5等其他人完成本指南。
Kelly
于01/18/12注册
566 声望
创作了6篇指南
团队
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G17
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 11,212
