跳转到主内容
  1. Place your Blackberry facedown in front of you.
    • Place your Blackberry facedown in front of you.
  2. Press the cover release button on the bottom of your device. Lift and remove the back cover.
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. From the top, use your fingernail to lift the battery out.
    • From the top, use your fingernail to lift the battery out.
  4. Remove the SIM card.
    • Remove the SIM card.
  5. Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Use the plastic opening tool to remove the rear case.
    • Use the plastic opening tool to remove the rear case.
  7. With the same plastic opening tool, lift the motherboard up and out. Remove the motherboard assembly from left to right, raise the bottom of the circuit board first, slide back to allow the board to come free of the slot way it is inserted into at the top, and use caution near the audio jack on the right side of the device.
    • With the same plastic opening tool, lift the motherboard up and out.
    • Remove the motherboard assembly from left to right, raise the bottom of the circuit board first, slide back to allow the board to come free of the slot way it is inserted into at the top, and use caution near the audio jack on the right side of the device.
  8. Holding the front cover, push the keyboard in with your thumbs.
    • Holding the front cover, push the keyboard in with your thumbs.
    • Start at the top two corners, then repeat with the bottom two corners.
结论
6等其他人完成本指南。
Kelly
于2012年01月18日注册
566 信誉积分
创作了6篇指南
团队
Cal Poly, Team 8-17, Maness Winter 2012 Cal Poly, Team 8-17, Maness Winter 2012 的会员
CPSU-MANESS-W12S8G17
4 名成员
创作了7篇指南
2条评论
This article describes removing the keypad button set and shows/describes nothing of replacing the keyboard electronics which controls the functionality of the keypad buttons. The keyboard electronics are on the reverse side of the motherboard assembly as seen in step 7. They are sealed beneath a sheet of plastic that contain a set of contact pads for the keyboard button set.
Most problems with this keyboard are likely associated with certain keys not functioning at all or responding in ways other than that intended. Repair/replacement looks improbable.
Ross - 回复
I had quite a few of the keyboard letters/numbers, spacebar and end call not functioning. Since I had the phone apart I decided to spray all of the keyboard white area and all the gold contact points around the perimeter with an electronic contact cleaner and wiped with a Q-tip. Reassembled it and - WOW - everything worked again. Thank you for the guide.
Ross -
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 5
总计 4,850
