跳转到主内容
Blackberry 8700c Battery Replacement
  1. Blackberry 8700c Battery Replacement, Battery: 步骤 1 中的图像 1,3 Blackberry 8700c Battery Replacement, Battery: 步骤 1 中的图像 2,3 Blackberry 8700c Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove the back cover by pushing the button near the bottom of the phone and sliding the cover off.
  2. Blackberry 8700c Battery Replacement: 步骤 2 中的图像 1,2 Blackberry 8700c Battery Replacement: 步骤 2 中的图像 2,2
    • Using your fingernail, remove the battery by pulling on the notch on the top-right of the battery.
    • If you are not installing a new battery, move on to the next step. If you are installing a new battery, read on.
    • Install the new battery by first placing the bottom end of the battery in the phone and then pushing the battery into place.
结论
To reassemble your Blackberry 8700c, follow these instructions in reverse order.
k3nt
于10/28/09注册
42 声望
创作了4篇指南
团队
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 2,820
