跳转到主内容
Blackberry 7520 Speaker Replacement
你所需要的
  1. Blackberry 7520 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Blackberry 7520 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 Speaker Replacement: 步骤 2 中的图像 1,3 Blackberry 7520 Speaker Replacement: 步骤 2 中的图像 2,3 Blackberry 7520 Speaker Replacement: 步骤 2 中的图像 3,3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Blackberry 7520 Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the six screws located on the rear of the phone.
  4. Blackberry 7520 Speaker Replacement: 步骤 4 中的图像 1,2 Blackberry 7520 Speaker Replacement: 步骤 4 中的图像 2,2
    • Use a pick or plastic iPod opening tool to push the clips, that are holding the rear casing. Apply a firm pressure at a forty-five degree angle to dislodge the clips.
    • Applying too much pressure could break the plastic clips and permanently damage the casing, so be careful.
  5. Blackberry 7520 Speaker Replacement: 步骤 5 中的图像 1,1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 Speaker Replacement: 步骤 6 中的图像 1,1
    • Do not try to pull the two pieces apart. You may tear the antenna cable. Instead, fold the two pieces open to avoid stress on the cable.
  7. Blackberry 7520 Speaker Replacement: 步骤 7 中的图像 1,1
    • Separating the two halves allows you to access the speaker. Which is located in the front half of the case.
  8. Blackberry 7520 Speaker Replacement: 步骤 8 中的图像 1,3 Blackberry 7520 Speaker Replacement: 步骤 8 中的图像 2,3 Blackberry 7520 Speaker Replacement: 步骤 8 中的图像 3,3
    • Insert a plastic opening tool between the speaker and the case. Then pry the speaker out.
    • To reinsert the speaker, align the blue notch to the blue stud. Then the red notch to the red stud. As shown in the last picture.
结论
Nathan
于01/18/10注册
31 声望
创作了6篇指南
团队
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G7
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,480
