当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn the phone upside down.
Push down on the black button on the back of the phone to slide the rear panel off.
The battery should be visible now.
Hold the BlackBerry in one hand face-up with the screen facing towards you.
Gently smack the phone against your hand to dislodge the battery.
Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
Use a pick or plastic opening tool to push the clips holding the rear away from you.
Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
Repeat the process of unlatching the clips for the top section of the Blackberry.
Slide the rear panel forward to reveal the motherboard.
Remove the indicated screws using a T6 Torx screwdriver.
Remove the motherboard.
Remove the indicated screw using the T6 Torx screwdriver.
Pull the metal plate away from the front panel of the cell phone.
Place the faceplate face-down and the interior of the phone face-up, as shown.
取消:我没有完成这个指南。
与8其他贡献者
于01/18/10注册
31 声望
创作了6篇指南
徽章: 5
+ 2更多徽章
CPSU-FORTE-W10S5G7
5 名成员
创作了9篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 14
总计 3,593
