简介
Disassembling the motherboard in the rear of the Blackberry allows you to get to the LCD screen and keypad.
配件
无需配件。
  1. Turn the phone upside down.
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
    • Slide the rear panel forward to reveal the motherboard.
    • Remove the indicated screws using a T6 Torx screwdriver.
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
    • Pull the metal plate away from the front panel of the cell phone.
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
结论
Nathan
于2010年01月18日注册
31 信誉积分
创作了6篇指南
团队
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G7
5 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 27
总计 3,488
