跳转到主内容
Blackberry 7520 LCD Screen Replacement
你所需要的
  1. Blackberry 7520 LCD Screen Replacement, Battery: 步骤 1 中的图像 1,2 Blackberry 7520 LCD Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 LCD Screen Replacement: 步骤 2 中的图像 1,3 Blackberry 7520 LCD Screen Replacement: 步骤 2 中的图像 2,3 Blackberry 7520 LCD Screen Replacement: 步骤 2 中的图像 3,3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 LCD Screen Replacement, Motherboard: 步骤 3 中的图像 1,2 Blackberry 7520 LCD Screen Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 LCD Screen Replacement: 步骤 4 中的图像 1,2 Blackberry 7520 LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 LCD Screen Replacement: 步骤 6 中的图像 1,2 Blackberry 7520 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 LCD Screen Replacement: 步骤 7 中的图像 1,2 Blackberry 7520 LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 LCD Screen Replacement: 步骤 8 中的图像 1,2 Blackberry 7520 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 LCD Screen Replacement: 步骤 9 中的图像 1,2 Blackberry 7520 LCD Screen Replacement: 步骤 9 中的图像 2,2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
  11. Blackberry 7520 LCD Screen Replacement, LCD Screen: 步骤 11 中的图像 1,1
    • Turn the phone so that it faces towards you.
  12. Blackberry 7520 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
  13. Blackberry 7520 LCD Screen Replacement: 步骤 13 中的图像 1,2 Blackberry 7520 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Pull the LCD screen off of the board.
结论
另外一个人完成了本指南。
Nathan
于01/18/10注册
31 声望
创作了6篇指南
团队
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G7
5 名成员
创作了9篇指南
一条评论
It’s too bad that iFixit didn’t post a teardown listing the parts for the BlackBerry 7520, since so little is known about its parts.
amosbatto - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,454
