简介
For removing and replacing the Blackberry 7520 battery, follow this guide.
工具
无需工具。
配件
无需配件。
Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
添加评论
Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
To install the battery turn the phone on its back. Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle) Once the battery is lined up push the battery in and down until it is locked in.
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
添加评论
Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone. Push the panel inwards then down until it locks in.
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
添加评论
终点
Nathan
于2010年01月18日注册
31 信誉积分
创作了7篇指南
团队
Cal Poly, Team 5-7, Forte Winter 2010 Cal Poly, Team 5-7, Forte Winter 2010 的会员
CPSU-FORTE-W10S5G7
5 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,423
