跳转到主内容
Blackberry 7105t Disassembly
你所需要的
  1. Blackberry 7105t Disassembly, Blackberry 7105t Disassembly: 步骤 1 中的图像 1,1
    • With the back of the device facing you, press down on the button while sliding the battery casing away from the speaker to remove it.
  2. Blackberry 7105t Disassembly: 步骤 2 中的图像 1,1
    • Use a plastic opening tool or fingernails to unclip the two hinges of the speaker covering and remove it.
  3. Blackberry 7105t Disassembly: 步骤 3 中的图像 1,1
    • Remove the battery by pushing against it from the right and then pulling towards you.
  4. Blackberry 7105t Disassembly: 步骤 4 中的图像 1,1
    • Remove the four screws indicated in the picture with a #T6 Torx Bit screwdriver and set them aside.
  5. Blackberry 7105t Disassembly: 步骤 5 中的图像 1,3 Blackberry 7105t Disassembly: 步骤 5 中的图像 2,3 Blackberry 7105t Disassembly: 步骤 5 中的图像 3,3
    • Use a plastic opening tool or your fingernails to remove the plastic backing.
    • Start with the seam indicated in the picture and slide the plastic opening tool until the case is seperated.
  6. Blackberry 7105t Disassembly: 步骤 6 中的图像 1,1
    • Unscrew the four screws indicated in the picture with #T6 Torx Bit screwdriver.
    • Place the four screws released from the phone in a plastic bag.
  7. Blackberry 7105t Disassembly: 步骤 7 中的图像 1,1
    • The black battery casing and logic board can now be separated for the following steps.
结论
kelogan
于11/04/09注册
1 声望
创作了2篇指南
团队
Cal Poly, Team 9-17, Regan Fall 2009 Cal Poly, Team 9-17, Regan Fall 2009 的会员
CPSU-REGAN-F09S9G17
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,139
