跳转到主内容
加入维修社区 - 创建账户
BlackMagic Hyperdeck Studio Mini Fan Replacement
你所需要的
视频概述
  1. BlackMagic Hyperdeck Studio Mini Fan Replacement, Unscrew the Outer Case: 步骤 1 中的图像 1,1
    • 4 Screws on each side
  2. BlackMagic Hyperdeck Studio Mini Fan Replacement, Remove Fan: 步骤 2 中的图像 1,1
    • 2 - Screws
    • 1 - Pull cable
  3. BlackMagic Hyperdeck Studio Mini Fan Replacement, Cut Off Connector from both the old and new fan: 步骤 3 中的图像 1,1
    • Leave some length to solder with and to reach connector on main board.
  4. BlackMagic Hyperdeck Studio Mini Fan Replacement, Prep Fan Wires and Connector Wires: 步骤 4 中的图像 1,1
    • Strip Wires, Tin Wires, and prep by adding heat shrink tubing on wires (before shrinking).
  5. BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: 步骤 5 中的图像 1,3 BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: 步骤 5 中的图像 2,3 BlackMagic Hyperdeck Studio Mini Fan Replacement, Solder Connecter to Fan: 步骤 5 中的图像 3,3
    • Solder the new fan to the old connector using the following pinout.
    • Adjust heat shrink tubing so it covers the solder joints and use heat gun to shrink tubing.
  6. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: 步骤 6 中的图像 1,2 BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-assemble fan to device with fan label facing out: 步骤 6 中的图像 2,2
    • Re-assemble fan to device with fan label facing out.
    • OPTIONAL - Use Small Round Nose Pliers to break off case grill to make fan even quieter.
  7. BlackMagic Hyperdeck Studio Mini Fan Replacement, Re-Assemble Case: 步骤 8 中的图像 1,1
    • Re-Assemble case.
结论
4等其他人完成本指南。
Kevin Krautle
于10/10/16注册
562 声望
创作了2篇指南
7指南评论
THANK YOU SO MUCH!!!! This was the perfect solution. The new Noctua fan even came with solderless connectors. The whole job only took 20 minutes. It is now completely silent!
tberntson - 回复
Just replaced mine monitoring the temperature now. As @tberntson mentioned, the fan comes with some Skotchlok connectors and no soldering even required. I can’t believe how quiet the new fan is. Complete night and day difference. Kevin, thanks so much for sharing this.
Adrian Cho - 回复
Hi! any one that have the part number for the Nactua fan with Skotchlok connectors is it NF-A4x20-PWM?
mikaelf - 回复
The connector you need is a Micro JST ZH 1.5mm 4-pin female connector. You can pick them up pre-wired on eBay.
Jamie - 回复
Thank you so much! I soldered it and it works great! So silent now that I can´t hear it at all!
pzacharias - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 84
总计 5,417
